Updated library now generally available. See the
blog post .
The Microvisor IoT Approach. See the
blog post .
You can migrate your project to FreeRTOS 202210.01 LTS or subscribe to the FreeRTOS Extended Maintenance Plan. See the
blog post .
Search and browse content in your preferred language. See the
blog post .
Receive security patches and critical bug fixes on FreeRTOS libraries for two years. See the
blog post .
This site requires JavaScript
to be enabled.
Click here to
view a static menu.
FreeRTOS Kernel Ports
No hardware yet? Don't worry - see the
Demo Quick Start page for links to Windows and Linux ports, as well as Arm Cortex-M3 QEMU projects.
Hardware Partner
Supported Processor Families
Supported Tools
Altera
Cyclone V SoC (ARM Cortex-A9), Nios II
Altera SoC EDS (ARM DS-5 with GCC), Nios II IDE with GCC
ARMv8-M Note this category is just for simulated targets. Other ARMv8-M targets are in their respective vendor categories.
ARM Cortex-M33 simulator
GCC (and ARMclang building the FreeRTOS ARMv8-M GCC port)
Atmel
SAMV7 (ARM Cortex-M7), SAM3 (ARM Cortex-M3), SAM4 (ARM Cortex-M4 ), SAMD20 (ARM Cortex-M0+), SAMA5 (ARM Cortex-A5), SAM7 (ARM7), SAM9 (ARM9), AT91, AVR and AVR32 UC3
IAR, GCC, Keil, Rowley CrossWorks
Cadence
Tensilica Xtensa
XCC with the Xtensa Xplora IDE
CEVA
SensPro, SensPro2, CEVA-BX1, CEVA-BX2, CEVA-X1, CEVA-X2, CEVA-XC16, CEVA-XM6, CEVA-XM4, CEVA-XC12, CEVA-XC4500
LLVM
Cortus
APS3
Cortus IDE with GCC
Cypress
PSoC 5 ARM Cortex-M3
GCC, ARM Keil and RVDS - all in the PSoC Creator IDE
Freescale
Kinetis ARM Cortex-M4, Coldfire V2, Coldfire V1, other Coldfire families, HCS12, PPC405 & PPC440 (Xilinx implementations) (small and banked memory models), plus contributed ports
Codewarrior, GCC, Eclipse, IAR
Infineon
TriCore, XMC4000 (ARM Cortex-M4F), XMC1000 (ARM Cortex-M0)
GCC, Keil, Tasking, IAR
Fujitsu (Now Spansion )
FM3 ARM Cortex-M3, 32bit (for example MB91460) and 16bit (for example MB96340 16FX)
Softune, IAR, Keil
Luminary Micro / Texas Instruments . See also TI .
All Luminary Micro ARM Cortex-M3 and ARM Cortex-M4 based Stellaris microcontrollers
Keil, IAR, Code Red, CodeSourcery GCC, Rowley CrossWorks
Microchip . See also Microsemi (now Microchip) .
PIC32MX, PIC32MZ, PIC32MZ EF, PIC24, PIC24EP, dsPIC, MEC14xx, CEC13xx, CEC17xx, MEC17xx, MEC51xx
MPLAB C32, MPLAB C30
Microsemi
MiFive (RISC-V), SmartFusion, SmartFusion2
IAR, Keil, SoftConsole (GCC with Eclipse)
NEC (now Renesas)
V850 (32bit), 78K0R (16bit)
IAR
Nuvoton
NuMicro M2351 (ARM Cortex-M23)
IAR, Keil
NXP Semiconductors
VEGAboard (RISC-V), LPC55S6x(ARM Cortex-M33), LPC1500 (ARM Cortex-M3), LPC1700 (ARM Cortex-M3), LPC1800 (ARM Cortex-M3), LPC1100 (ARM Cortex-M0), LPC2000 (ARM7), LPC4000 (ARM Cortex-M4F/ ARM Cortex-M0)
GCC, Rowley CrossWorks, IAR, Keil, LPCXpresso IDE, Eclipse, MCUXpresso IDE
Renesas
RZ/A1 / RZ/A2M, (ARM Cortex-A9), RZ/T, RX700 / RX71M, RX600 / RX64M / RX62N / RX63N / RX65N, RX200, RX100, SuperH, RL78, H8/S plus contributed ports
GCC, e2 studio, IAR Embedded Workbench, HEW (High Performance Embedded Workbench)
SiFive
RISC-V RV32
Freedom Studio (GCC), IAR
Silicon Labs [ex Energy Micro]
EFM32 Gecko (Cortex-M3 and Cortex-M4F), 8051 compatible microcontrollers.
Simplicity Studio (GCC), IAR, SDCC
Spansion
Softune, IAR, Keil
ST
STM32 (ARM Cortex-M0, ARM Cortex-M7, ARM Cortex-M3 and ARM Cortex-M4F), STR7 (ARM7), STR9 (ARM9)
IAR, Atollic TrueStudio, GCC, Keil, Rowley CrossWorks
TI
RM48, TMS570, ARM Cortex-M4F MSP432, MSP430, MSP430X, SimpleLink, Stellaris (ARM Cortex-M3, ARM Cortex-M4F)
Rowley CrossWorks, IAR, GCC, Code Composer Studio
Xilinx
Zynq, Zynq UltraScale+ MPSoC (64-bit ARM Cortex-A53 and 32-bit ARM Cortex-R5), Microblaze, PPC405 running on a Virtex4 FPGA, PPC440 running on a Virtex5 FPGA.
GCC
Intel/x86
IA32 (32-bit flat memory model), Quark SoC X1000 (32-bit flat memory model), any x86 compatible running in Real mode only, plus a Win32 port . A port for the Linux Simulator is available as well. .
GCC, Visual Studio 2010 Express, MingW, Open Watcom, Borland, Paradigm
Tricore, MICO32, Blackfin, Jennic, eZ80, SuperH and others.
Contributed Ports
Contributed ports are provided "as is" and are not supported directly.
