Updated Apr 2025
Supported Devices
Hardware Partner | Supported Processor Families | Supported Tools |
A | ||
Altera | Cyclone V SoC (ARM Cortex-A9), Nios II | Altera SoC EDS (ARM DS-5 with GCC), Nios II IDE with GCC |
ARMv8-M Note this category is just for simulated targets. Other ARMv8-M targets are in their respective vendor categories. | ARM Cortex-M33 simulator | GCC (and ARMclang building the FreeRTOS ARMv8-M GCC port) |
Atmel | SAMV7 (ARM Cortex-M7), SAM3 (ARM Cortex-M3), SAM4 (ARM Cortex-M4 ), SAMD20 (ARM Cortex-M0+), SAMA5 (ARM Cortex-A5), SAM7 (ARM7), SAM9 (ARM9), AT91, AVR and AVR32 UC3 | IAR, GCC, Keil, Rowley CrossWorks |
C | ||
Cadence | Tensilica Xtensa | XCC with the Xtensa Xplora IDE |
CEVA | SensPro, SensPro2, CEVA-BX1, CEVA-BX2, CEVA-X1, CEVA-X2, CEVA-XC16, CEVA-XM6, CEVA-XM4, CEVA-XC12, CEVA-XC4500 | LLVM |
Cortus | APS3 | Cortus IDE with GCC |
Cypress | PSoC 5 ARM Cortex-M3 | GCC, ARM Keil and RVDS - all in the PSoC Creator IDE |
F | ||
Freescale | Kinetis ARM Cortex-M4, Coldfire V2, Coldfire V1, other Coldfire families, HCS12, PPC405 & PPC440 (Xilinx implementations) (small and banked memory models), plus contributed ports | Codewarrior, GCC, Eclipse, IAR |
I | ||
Infineon | AURIX™ TC3xx, XMC4000 (ARM Cortex-M4F), XMC1000 (ARM Cortex-M0) | GCC, Keil, Tasking, IAR |
Fujitsu (Now Spansion) | FM3 ARM Cortex-M3, 32bit (for example MB91460) and 16bit (for example MB96340 16FX) | Softune, IAR, Keil |
L | ||
Luminary Micro / Texas Instruments. See also TI. | All Luminary Micro ARM Cortex-M3 and ARM Cortex-M4 based Stellaris microcontrollers | Keil, IAR, Code Red, CodeSourcery GCC, Rowley CrossWorks |
M | ||
Microchip. See also Microsemi (now Microchip). | PIC32MX, PIC32MZ, PIC32MZ EF, PIC24, dsPIC33C, dsPIC33E, dsPIC33F, MEC14xx, CEC13xx, CEC17xx, MEC17xx, MEC51xx | XC Compilers |
Microsemi | MiFive (RISC-V), SmartFusion, SmartFusion2 | IAR, Keil, SoftConsole (GCC with Eclipse) |
N | ||
NEC (now Renesas) | V850 (32bit), 78K0R (16bit) | IAR |
Nuvoton | NuMicro M2351 (ARM Cortex-M23) | IAR, Keil |
NXP | VEGAboard (RISC-V), LPC55S6x(ARM Cortex-M33), LPC1500 (ARM Cortex-M3), LPC1700 (ARM Cortex-M3), LPC1800 (ARM Cortex-M3), LPC1100 (ARM Cortex-M0), LPC2000 (ARM7), LPC4000 (ARM Cortex-M4F/ ARM Cortex-M0) | GCC, Rowley CrossWorks, IAR, Keil, LPCXpresso IDE, Eclipse, MCUXpresso IDE |
R | ||
Renesas | RZ/A1 / RZ/A2M, (ARM Cortex-A9), RZ/T, RX700 / RX71M, RX600 / RX64M / RX62N / RX63N / RX65N, RX200, RX100, SuperH, RL78, H8/S plus contributed ports | GCC, e2 studio, IAR Embedded Workbench, HEW (High Performance Embedded Workbench) |
S | ||
SiFive | RISC-V RV32 | Freedom Studio (GCC), IAR |
Silicon Labs [ex Energy Micro] | EFM32 Gecko (Cortex-M3 and Cortex-M4F), 8051 compatible microcontrollers. | Simplicity Studio (GCC), IAR, SDCC |
Spansion | FM3 ARM Cortex-M3, 32bit (for example MB91460) and 16bit (for example MB96340 16FX) | Softune, IAR, Keil |
ST | STM32 (ARM Cortex-M0, ARM Cortex-M7, ARM Cortex-M3 and ARM Cortex-M4F), STR7 (ARM7), STR9 (ARM9) | IAR, Atollic TrueStudio, GCC, Keil, Rowley CrossWorks |
T | ||
TI | RM48, TMS570, ARM Cortex-M4F MSP432, MSP430, MSP430X, SimpleLink, Stellaris (ARM Cortex-M3, ARM Cortex-M4F) | Rowley CrossWorks, IAR, GCC, Code Composer Studio |
X | ||
Xilinx | Zynq, Zynq UltraScale+ MPSoC (64-bit ARM Cortex-A53 and 32-bit ARM Cortex-R5), Microblaze, PPC405 running on a Virtex4 FPGA, PPC440 running on a Virtex5 FPGA. | GCC |
Intel/x86 | IA32 (32-bit flat memory model), Quark SoC X1000 (32-bit flat memory model), any x86 compatible running in Real mode only, plus a Win32 port. A port for the Linux Simulator is available as well. | GCC, Visual Studio 2010 Express, MingW, Open Watcom, Borland, Paradigm |
Tricore, MICO32, Blackfin, Jennic, eZ80, SuperH and others. | Contributed Ports | Contributed ports are provided "as is" and are not supported directly. |
